30 W Compact DC-DC Converter has 4:1 Input
By Design World Staff | October 30, 2007
V-Infinity, a division of CUI Inc, has launched a new line of 30 W dc-dc converters.  The VSCQ30 series is compact, has a wide 4:1 input range, and excels in environments where space is at a premium and high efficiency is demanded.  The pin mount version measures 2 x 1.6“.  This series also has an available “T” chassis mount version for mounting convenience.
The VSCQ30 series has an input range from 9-36 Vdc at a nominal input of 24 V or 18-75 Vdc input range at nominal input of 48 V.  Output options range from 3.3-15 Vdc.  The series operates over a wide temperature range and is up to 91% efficient.  It comes with industry standard pin-out in a six-sided metal case.  Other features include fixed 300 KHz switching frequency, regulated outputs, and continuous short circuit protection.  OEM pricing starts at $38 per unit.
Summary:
• VSCQ30 series power supply
• Availability:  4-6 weeks production
• Possible users:  applications where space is at a premium
• Primary feature:  compact dc-dc converter provides 30 W of power
• Cost:  OEM pricing starts at $38 per unit
www.cui.com
Filed Under: Converters (electrical) AD + DA • transformers, Power supplies, ELECTRONICS • ELECTRICAL
