GERMANTOWN, WI ‚– An industry-exclusive 3.5mm-wide terminal block rated for 600 volts leads the new 2000 Series from WAGO Corporation‚’s TOPJOB‚®S family. The 2000 Series terminal blocks provide fast, vibration-proof terminations to space-restricted machinery and building installations requiring conductors 16‚–24 AWG.
The 2000 Series TOPJOB‚®S provides maintenance-free, push-in terminations for solid or ferruled conductors. Stripped stranded conductors are easily terminated via screwdriver actuation. Available in 2-, 3- and 4-conductor feed through and ground terminal blocks, TOPJOB‚®S anchors WAGO‚’s line of spring pressure DIN-rail mount terminal blocks, which spans from 24 AWG to 4/0.
Filed Under: Terminal blocks, ELECTRONICS • ELECTRICAL
