360° static eliminator is CE, UL and RoHS certified
By Mike Santora | January 18, 2019
EXAIR-360-degree-static-eliminatorEXAIR’s new Gen4 Super Ion Air Wipe provides a uniform 360 degree ionized airstream that clamps around a continuously moving part to eliminate static electricity and contaminants. It is ideal for removing dust, particulates and personnel shocks on pipe, cable, extruded shapes, hose, wire and more. This engineered product has undergone independent laboratory tests to certify it meets the rigorous safety, health and environmental standards of the USA, European Union and Canada that are required to attain the CE and UL marks. It is also RoHS compliant. New design features include a metal armored high voltage cable to protect against abrasion and cuts, a replaceable emitter point, integrated ground connection and electromagnetic shielding.
The Super Ion Air Wipe uses a small amount of compressed air to entrain high volumes of room air. Two shockless ionizing points powered by a UL Component Recognized 5kV power supply fills the airstream with static eliminating ions. That airflow attaches itself to the surface of the material running through the air wipe and neutralizes the charge.
The Super Ion Air Wipe, which compliments EXAIR’s complete line of Gen4 Static Eliminators, has an aluminum construction that is lightweight and easy to mount using the tapped holes provided. Two sizes include a 2 inch (51mm) diameter and a 4 inch (102mm). There are no moving parts to wear out. Visit EXAIR.com to see the entire Gen4 Static Eliminator product line and 1/2 inch through 11 inch Super Air Wipes for applications without static.
EXAIR
www.exair.com
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES
Tagged With: exair
engineering in plain sight
Book review: A plain explanation of every day engineering
watlow-logo
Watlow signs agreement to acquire Eurotherm from Schneider Electric
Owariasahi Factory
Mitsubishi Electric to establish new production site for factory automation control system products
