Gantri, a direct-to-consumer designer lights manufacturer, unveiled its first 3D printer named “Gantri Dancer.” This commercial multi-gantry cylindrical 3D printer leverages four gantries and a rotating circular build plate to print up to four times as fast as best-in-class desktop 3D printers while maintaining a high standard of product quality.
“Gantri’s mission is to empower designers to create by using advanced technologies,” said Christianna Taylor, PhD and CTO at Gantri. “Our goal is to push for the adoption of digital manufacturing as an alternative to today’s industrial manufacturing system in producing high-quality consumer grade products. Dancer is specifically designed to manufacture consumer-grade products at the quality and speed that Gantri requires.”
How It’s Different
• Coordinated multi-gantry system – Using a rotating circular build plate, all four gantries of Dancer can work together concurrently to print one part. As a result, there is no “deadzone” void in the middle and we can print the same part using only a quarter of the time.
• Complete front access – Print bed access, maintenance, and spool change are all done from the front, enabling complete automation in the near future.
• Large build volume – At 18”R x 24”H, it’s one of the largest desktop-grade printers in the world.
• Custom-designed casing – aerospace-grade aluminum frame and polycarbonate panels offer a light, sturdy body that minimizes vibration and is quick to assemble.
• Automatic 3D model translation – Gantri developed a unique translation algorithm that converts current modeling system into Dancer’s coordinated multi-gantry system with no additional input from the user.
• Leverage sustainable materials – Dancer is designed to use Gantri’s exclusive corn-based PLA, which requires consistently high-temperature output to facilitate kneading.
• Fleet-management – Dancer is wireless-enabled and connects directly to Gantri’s online order system.
• Made using 3D printing – Dancer is made and assembled by Gantri in California. 60% of all Dancer parts are 3D printed.
Starting in November 2019, Gantri will start migrating its entire printer fleet to Dancer at the Gantri Factory in San Leandro, California. As a result, Gantri estimates that the average “Made for you” production lead time will decrease from about four weeks currently to two weeks.
Gantri
www.gantri.com
Filed Under: 3D printing • additive manufacturing • stereolithography
