The ROMER Absolute Arm 1.2m portable coordinate measuring machine (CMM) is a portable measuring arm that delivers high-accuracy 3D measurement in a 1.2 m volume. It is for use in confined spaces, including inside a machining center for dimensional control of molds, parts, tooling, castings, and more.
The ROMER Absolute Arm 1.2m streamlines the measurement process and is an alternative to manual tools such as height gages, dial calipers, bore gages, gage blocks, micrometers, and dial indicators.
A counterweight system simplifies set-up; the arm does not need to be mounted to a surface to use. Absolute encoders, a standard feature on the Absolute Arm line, eliminate complicated referencing procedures. The operator can start measuring with merely the flip of a switch.
ROMER Absolute Arm allows wireless battery-powered operation for portability on the shop floor. An integrated camera and work-light facilitate inspections in harsh environments.
This arm is a replacement for the ROMER MultiGage. The ROMER Absolute Arm 1.2m is available in two models and can be certified to ISO 10360-2 or B89.4.22. Usability features include automatic probe recognition to ensure repeatable results for different probes without calibration and haptic feedback to alert users if an axis limit is reached, eliminating the risk of bad measurements.
The ROMER Absolute Arm 1.2m is also compatible with all major metrology software packages including PC-DMIS Touch, the revolutionary measurement software that uses high-resolution Multi-Touch display technology on a tablet PC.
Hexagon Metrology
www.hexagonmetrology.us
Filed Under: Automotive, Medical
