3D Systems adds new materials to its portfolio
By PR Editor | September 2, 2021
3D Systems announced two additions to its industry-leading materials portfolio – Certified Scalmalloy (A) and Certified M789 (A) – to facilitate demanding industrial high-strength, corrosion-resistant parts for additive applications in markets such as aerospace, motorsports & automotive, semiconductor, energy, and moldmaking. This action enables the company’s customers to use these high-performance materials optimized for metal additive manufacturing on its Direct Metal Printing (DMP) platform. Additionally, 3D Systems has worked with the material manufacturers – APWORKS and voestalpine BÖHLER Edelstahl – to certify these materials for use with its metal 3D printing technology. Customers now have the ability to work with the company’s Application Innovation Group (AIG) to efficiently certify these materials for use with its DMP Flex 350 and DMP Factory 350 printers – gaining a competitive advantage with faster time to market.
Scalmalloy
Scalmalloy is a high-strength Aluminum alloy that has a tensile strength of 520MPa and yield strength of 480MPa, significantly stronger than the reference material AlSi10Mg. The high strength of Scalmalloy makes it ideal for additively manufacturing weight-efficient, load-bearing components. Using this material, manufacturers are able to produce high-strength, corrosion-resistant Aluminum parts facilitated by fully-developed build styles available in 3DXpert® software for the company’s DMP Flex 350 and DMP Factory 350 metal 3D printers. Additionally, parts produced using Scalmalloy can be chemically cleaned during post-processing which removes surface residue to deliver a final part with optimal surface finish. Ideal applications for this material include:
• Aerospace: passive RF components (e.g., filters, waveguides, etc.), lightweight structural components
• Motorsports & Automotive: metal structural components (e.g., suspension brackets, transmission casings), energy and fluid management
• Semiconductor: fluid flow (e.g., manifolds), thermal management (e.g., cooling nozzles, wafer tables)
Suspension rocker produced in Certified Scalmalloy (A) on 3D Systems DMP Flex 350 metal 3D printer. With its high strength, this aluminum material – specifically developed for metal additive manufacturing – enables customers to further reduce mass in metal structural components.
“Adding the capability to additively manufacture parts from Scalmalloy to our portfolio is an important step forward; especially for our aerospace customers,” said Dr. Michael Shepard, vice president, aerospace & defense segment, 3D Systems. “Scalmalloy has a very attractive strength-to-weight ratio and is more amenable to 3D printing than many conventional high-strength Aluminum alloys. These performance attributes make it ideal for aerospace applications and we are excited to see how our customers will use 3D printed Scalmalloy components to continue to push the envelope with their innovation.”
M789 (BÖHLER M789 AMPO)
M789 allows 3D Systems’ customers to produce high-strength molds and tooling that can not only be hardened up to 52HRC but are also free of Cobalt. 3D Systems has attained certification of M789 for its DMP platform through collaboration with its partner, GF Machining Solutions, addressing customers’ requests for a hard, corrosion-resistant tooling steel to foster advanced applications. The resulting parts are optimal for long-term use, able to withstand both the rigors of repetitive manufacturing processes as well as use in regions with high humidity. Ideal applications for this material include:
• Moldmaking: mold inserts with conformal cooling
• Energy: drill bits, cutting tools
• Automotive: tire molds, drive train parts, axle components
High-strength mold insert for air vents produced with metal additive manufacturing in Certified M789 (A) cobalt free tool steel. Integrated conformal cooling channels manage heat dissipation, achieve uniform cooling, reduce warping and deformation while achieving better overall injection molding economics.
“Our customers in the automotive industry are increasingly relying on additive manufacturing to advance and accelerate their innovation,” said Kevin Baughey, segment leader, transportation & motorsports, 3D Systems. “Having M789 as part of our metal 3D printing solution delivers greater accuracy to our automotive customers. This is enabling them to use the technology for applications that require higher fidelity and thinner walls, like die inserts with conformal cooling and tire tread molds, and providing them a competitive advantage.”
At RAPID+TCT 2021 to be held September 13-15 at McCormick Place in Chicago, attendees can visit 3D Systems in booth E7601 to further explore the advantages of these materials. Visitors will have the opportunity to not only see parts produced using these new materials but also to speak with the company’s application experts to explore how Scalmalloy and M789 can be used to meet their unique application challenges.
3D Systems
www.3dsystems.com
Filed Under: Make Parts Fast
Tagged With: 3dsystems
SPEE3D releases high velocity Phaser Nozzle for its metal 3D Printer
AMGTA publishes process to safely transport and recycle metal powder condensate waste
Velo3D announces the Sapphire XC 1MZ for large-format metal 3D Printing
Going digital with additive manufacturing
