3D Systems & Airbus Defence and Space create novel passive RF components for fully reconfigurable satellite
By PR Editor | May 12, 2022
3D Systems announced the company has been selected by Airbus Defence and Space to produce critical components for its industry-first satellite innovation, OneSat. 3D Systems’ Application Innovation Group (AIG) has designed an end-to-end additive manufacturing solution – comprising materials, 3D printing technology, software, and applications expertise – to produce the components required for the large antenna array on these satellites. Additively manufacturing these components offers design freedom to enable weight reduction, part performance optimization, and faster time to market which aids in more rapid deployment of these unique satellites to meet end-users’ needs. 3D Systems was selected for this important project based on the part quality achievable with its DMP systems as well as its demonstrated expertise and performance working with Airbus Defence and Space over the past seven years. Previous collaborations include production of the first 3D printed radio frequency (RF) filter tested and validated for use in commercial telecommunications satellites and the production of innovative switch assembly network designs for two Eurostar Neo spacecraft as part of the first large-scale deployment of RF products using direct metal printing.
Each OneSat satellite requires two large antenna arrays, one to transmit signals and one to receive. 3D Systems’ DMP Factory 500 Solution will be employed for serial production of the antennae components using LaserForm AlSi10Mg and specific parameters developed by the AIG for this application to achieve the required 30µm layer thickness. The DMP Factory 500 was selected for this project based on its build volume (500mm x 500mm x 500mm), accuracy, and rapid print speed. The intelligent multi-laser configuration of this printer enables the production of seamless large parts resulting in the highest surface quality with outstanding material properties. The printer includes a unique vacuum chamber that allows for the lowest possible oxygen (O2) content in the build chamber protecting chemical composition and reducing the moisture content of the metal powder alloys during manufacturing. This ensures optimum operating conditions for consistent part quality (e.g., mechanical properties and surface homogeneity), which is necessary for an industry with such high requirements for quality and precision. The DMP Factory 500 also includes 3DXpert® which supports every step of the additive manufacturing workflow from design to post-processing, to quickly and efficiently transition from a 3D model to successfully printed parts.
In addition to providing design and production expertise, 3D Systems’ Application Innovation Group is also acting in the capacity of project manager. The company has identified subcontractors that are conducting post-processing and quality inspection, thus delivering a comprehensive end-to-end solution designed to help Airbus Defence and Space mitigate risk and reduce time to market. The AIG is also leading the technology transfer process, whereby they will enable another tier 1 supplier to quickly ramp production of these fully-qualified components. The supplier is also purchasing another DMP Factory 500 to complement its existing fleet and allow it to meet the quality levels required by Airbus.
“We value our long-standing partnership with Airbus Defence and Space, and are pleased with how our collective work continues to make its mark in telecommunications satellites,” said Dr, Michael Shepard, vice president, aerospace & defense segment, 3D Systems. “As with our earliest work with Airbus on the first additively manufactured RF filter, we have the opportunity to bring another ‘first’ to the industry that is changing telecommunications. Our AIG has laid the groundwork for developing the application for this component and completing the technology transfer. We’re proud that 3D Systems’ technology can help lay the foundation for Airbus to build a strong supply chain for serial production of passive RF hardware.”
“OneSat is a truly disruptive product, and we wanted our design and manufacturing process to possess that same level of innovation,” said Stephen Phipps, OneSat antenna program manager, Airbus Defence and Space. “Our company has a strong partnership with 3D Systems and has relied on its team of application engineers to help us bring our most advanced designs to life. Everything from the quality of the parts produced using their printers, through to parts qualification, quality management, and overall project management have helped Airbus Defence and Space maintain its position as an industry leader.”
3D Systems
www.3dsystems.com
Filed Under: Make Parts Fast
Tagged With: 3dsystems
EOS and Sauber Technologies sign three-year additive manufacturing technology partnership
PostProcess launches a solution for automated wax support removal
Korea Maritime and Ocean University scholars find key to reducing defects in multimaterials
SPEE3D’s metal 3D technology to print military maritime parts to help reduce supply chain issues
