In order to meet the miniaturization and energy saving demands for related end electronic products from the industrial and control market, MEAN WELL is pleased to unveil the 45W/65W ~EPS-45S/65S series with merely 3” x 2” PCB board size after the same 45W/65W EPS-45/65 series (4” x 2”) were released. The features of these two series are miniature size (3” x 2”), ultra low no load power consumption (<0.1W), less-than-1U low profile design (only 24mm high) that is well suitable for those low-cost applications installed inside the system cabinets without the need of the power enclosures. Suitable applications include industrial electric equipments, electro-mechanical instruments, factory automation systems, electronic devices which demand low no load power consumption.
The industrial power supply features:
3” x 2” miniature PCB size
Ultra low no load power consumption <0.1W
24mm low profile
80~264VAC full range input
Class II power unit (without FG)
High efficiency up to 91%
Working temperature:-30~+70°C
Complete protection functions: Short circuit / Overload / Over voltage
Cooling by free air convection
LED indicator for power on
Approved for UL/CUL/TUV/CB/CE
Dimension (L x W x H): 76.2 x 50.8 x 24 mm
3 years warranty
Filed Under: Power supplies, Power Electronic Tips
