48 mm hollow-shaft brushless motors
By Frank Tobe | October 29, 2015
Koford Engineering’s new line of 12 to 24 V, 48 mm diameter slotless brushless hall sensor motors feature a 10 mm hole through the center of the motor shaft. The motor features a free running temperature rise as low as 3°C which can be helpful for optical and scientific instrument applications. Ceramic hybrid bearings are used for optimum bearing life and low drag. Windings are offered with no load rpm from 3,873 to 24,360 rpm. Peak output is up to 57 W and the operating temperature is -30 to 100°C. Matching digital drives are available.
For more information, visit www.koford.com.
Koford 1
The post 48 mm hollow-shaft brushless motors appeared first on Motion Control Tips.
Filed Under: Bearings
Tagged With: koford
