5-Phase Step Motor and Driver/Controller Systems
By Design World Staff | November 13, 2009
The CRK Series of 5-Phase stepping motors and drivers with built-in RS-485 compatible controller packages offer motion that is smooth, quiet, and accurate. The RS-485 based controller allows for up to 16 axes to be controlled from one RS-485 Master controller. Five network communications rates of up to 115,000 BPS can be selected. Connection to the network is through conveniently located RJ-45 connectors. The controller can be operated in either direct command mode, stand alone mode or by selecting stored programs to run via I/O. Programming is done via simple ASCII commands that can be sent to the controller via any basic PC based terminal program or PLC device.
This series uses 5-Phase microstepping technology. The standard series motors offer step resolutions up to 0.00288°/step with step accuracy of 3 Arc Min (0.05°). The high resolution models have step resolutions to 0.00144°/step and step accuracy of 2 Arc Min (0.034°).
Oriental Motor
www.orientalmotor.com
Filed Under: Drives (stepper) + amplifiers, Motion control • motor controls, Motors • stepper
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
