    • On the Floor
6mm Interface Relays from IDEC
By Patrick Curran | November 1, 2011
IDEC’s newest 6mm interface relay offers  the lowest height in the market and competitive pricing, RV8H relays are ideal for space saving applications requiring smaller machines and panels.
IDEC is excited to introduce a new series of 6mm interface relays to our existing line of high-quality relays. IDEC RV8H 6mm interface relays provide a compact solution for general purpose relay requirements. These relays are ideal for PLC and electronic systems, industrial automation, panel builders, assembly machine applications and other applications that require a high switching capability in a compact space. RV8H relays can be used as universal interfaces between the controller and the actuator to switch small and medium size loads.
These IDEC relays have undergone rigorous quality control testing and gold-plated contacts create better contact and more reliable switching with 6A or lower signal levels.
Operating temperatures range from -40 to +70 °C along with a wide input voltage range of 6 to 240V.
The combination of RV relays and SV sockets are UL listed. Optional accessories include jumpers, spacers and marking plates to facilitate wiring and quick identifications.
IDEC
www.IDEC.com/relays
Filed Under: Factory automation, Relays, ELECTRONICS • ELECTRICAL, PLCs + PACs
  • Toyota goes all-in on humanoid robots
    • On the Floor
