6U-600-W cPCI Power Supply Features Advanced Status and Control Functions
By atesmeh | March 30, 2011
Gresham Power Electronics announced its 6U 600W cPCI power supply. This RoHS-compliant power supply family has advanced status and control functions including remote inhibit, output fail alarm, over temperature warning, output remote sense, single wire current share and front panel LEDs indicate outputs OK and any fault condition. The supplies are fully compliant with the PICMG 2.11 power interface specification, incorporate the standard Positronic 47-pin connector and offer hot-swap, N+1 redundant connection and active load current share. These cPCI power supplies incorporate active power factor correction, an 85 V to 264 VAC universal AC input voltage or DC input covering a range from 36V to 72VDC Standard output voltages are 5 V/70 A +3.3 V/70 A +12 V/7 A -12 V/1.5 A and custom variants are possible. All models have a monitor and control (M&C) system based on an intelligent I²C bus providing comprehensive remote status monitoring and control functionalities. Gresham Power compactPCI products are suitable for industrial, communications, broadcast and advanced multi-media applications.
44 1722 413060, www.greshampower.com
