70 Watt Brushless DC Motor with gear and encoder options from maxon
By Miles Budimir | September 15, 2011
maxon motor’s newly designed 70 Watts flat brushless motor delivers a maximum continuous torque of 130 mNm at an efficiency of up to 85%. The new motor in its 45 mm diameter is available with Hall sensors and comes in four windings (24, 30, 36, 48 V). It can be combined with more than 54 different planetary and spur gearheads. For motion control purposes, maxon provides a wide selection of servo controllers and positioning controllers.
maxon-70-Watt-Brushless-DC-Motor
maxon’s design of the brushless DC flat motors makes them the ideal drive for many applications. Designed as internal or external rotor motors, they are often the ideal solution when space is limited. It is the ideal choice for use in self-contained drive systems as well as in industrial automation applications.
maxon motor
http://www.maxonmotorusa.com
Filed Under: Factory automation, Motion control • motor controls, Motors • dc
Comments
  1. Raymond Chaine says
    September 3, 2016 at 8:50 pm
    I am looking for 12 volts DC motors, 70 watts, 1.20 Amp flat flange type mounting,
    0 to1200 rpm, forward and reverse
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
