Ø8 mm Precision Zero-Backlash Spur Gearhead
By Kathleen Zipp | February 8, 2007
Clearwater, Florida (February 1, 2007) – MicroMo Electronics, Inc. announced the addition of a metal spur zero backlash gearhead with the release of the Series 08/3.  The gearhead is ideal for applications that require precision positioning with high resolution and low torque.  It weighs only 4.5 to 5.7 g, but provides a maximum continuous torque of 15 mNm, with intermittent torque to 25 mNm.  The 08/3 has a diameter of 8 mm and length from 18.8 mm to 24.2 mm.  It comes with four standard ratios for precise positioning, speed reduction, and torque multiplication and is available with ball bearings.  The gearhead is equipped with standard threaded holes on the drive side for easy mounting.  It is preloaded at MicroMo and comes already assembled to the motor.
The Series 08/3 Precision Zero-Backlash Gearhead can be combined with a motor and encoder for a complete miniature DC drive system.  The gearbox can be used with the Series 0816 DC-Micromotor and the AM0820 miniature DC stepper motor from MicroMo.  The motor and gearbox can be combined with magnetic or optical encoders, which enables precise control of speed and direction of rotation, as well as positioning of the drive shaft.
It is immediately available in ratios of 120:1, 279:1, 650:1, and 1,518:1 with ball bearings from stock.
About MicroMo Electronics and the FAULHABER Group
MiCroMo Electronics has its headquarters in Clearwater, Florida.  It manufactures some of the world’s smallest high-precision DC drive systems, components, and controls.  MicroMo is a member of the FAULHABER Group, which specializes in the design and manufacture of complex, high-precision miniature and micro drive systems for applications such as, medical devices, handling automation, telecommunications, and precision optics.
For additional information and samples, please contact a MicroMo Electronics Application Engineer at 800-807-9166.
Email: [email protected]
WWW: www.micromo.com
:: Design World ::
Filed Under: Factory automation, Encoders • optical, Gears • gearheads • speed reducers
