The BI12-EG30F-AG6X stainless steel faced sensors are a good replacement for traditional plastic faced sensors in applications where the sensors are routinely damaged by impact.
The one-piece housing is made from high-grade stainless steel which resists corrosion and is rated IP67 against moisture ingress.
The standard temperature rating for the line is -25 to +70 °C, and power input is 10 to 30 VDC. Units are available with 2, 3, 7 and 12 mm sensing ranges. The rugged construction and design allow the sensors to fit the needs of a wide variety of applications. PTFE or WeldGuard coating is available upon request.
Turck
turck.us
Filed Under: Sensor Tips
