  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • DIGITAL ISSUES
      • EE World Digital Issues
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
Inspection kit detects hydraulic fluid leaks and injection injuries
By Michelle DiFrangia | May 13, 2016
SB-450 SafetyBlu Kit contents_TightSpectroline’s SafetyBlu (SB-450) Blue Light Inspection Kit is the only hydraulic system maintenance tool that saves you money two ways. Not only can SafetyBlu help find expensive hydraulic system leaks, it also helps detect and prevent dangerous injection injuries.
Mining Hydraulic Leak
Featuring a portable, high-intensity blue light (450 nm) LED flashlight, when used in conjunction with the company’s FluidSafe fluorescent additive, the SB-450 kit is successful in pinpointing the smallest fluid leaks in hydraulic system hoses, fittings, seals and other components. This allows tiny leaks to be repaired before they lead to big, catastrophic failures.
Not only can SafetyBlu help prevent the unexpected, it can lower anticipated operating costs by reducing hydraulic fluid consumption by up to 7% of your total annual hydraulic fluid budget.
When added to the reservoirs of hydraulic machinery, FluidSafe aids in the detection and surgical removal of hydraulic fluid in the event of an accidental fluid injection that penetrates the skin. That’s because when viewed under the SafetyBlu lamp’s high-intensity blue light, the additive’s bright green fluorescent glow pinpoints the injection track quickly and accurately. This makes it easy for medical personnel to confirm whether a penetration actually occurred, and if so, to precisely determine the extent of the injury.
The lamp features a rugged, anodized aluminum body, which reduces corrosion and stands up to years of heavy use. Powered by a rechargeable NiMH battery, it provides 90 minutes of continuous inspection between charges.
Injection injury inspection
In addition to the SafetyBlu flashlight, the SB-450 kit comes complete with smart ac and dc chargers, yellow fluorescence-enhancing glasses, a protective rubber bumper and a belt holster. All components are packed in a padded carrying case.
Spectroline
www.spectroline.com
The post Inspection kit detects hydraulic fluid leaks and injection injuries appeared first on Hose Assembly Tips.
MOTION DESIGN GUIDES
  • Drilling rig OEM benefits from a PLC with edge computing technology: IIoT case study
  • The industry shift to smart electromechanical actuators
  • Commemorating a great entrepreneurial personality – Oskar Lapp at 100 – A pioneer for the future
  • SE motor – uncompromised motion performance
  • With virtual commissioning, commissioning time and prototype waste is reduced
  • Master Bond Supreme 10HT High strength, NASA low outgassing approved epoxy
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • DIGITAL ISSUES
    • Suppliers
  • COVID-19
