AutomationDirect’s miniature inductive proximity sensors are now available in sizes ranging from 4mm to 8mm and feature stainless steel shielded housings. Offered as NPN or PNP models and with normally-open or normally-closed outputs, sensors are available with standard sensing distances of 0.8mm or 1.5mm; available extended distance models have either 1.5mm or 2mm sensing ranges. The miniature sensors are IP67-rated, are equipped with a 360-degree-visible yellow output LED and come with built-in overload protection. Starting at $16.00, models are offered with an attached 2-meter axial cable or with an M8 connector; axial and right angle zinc-plated mounting brackets are also available for $1.00 each. The new miniature inductive proximity sensors are CE, RoHs and Reach compliant.
<img src=”http://www.sensortips.com/wp-content/uploads/2016/05/MD-proximity-sensors.jpg” alt=”MD-proximity-sensors” width=”500″ height=”357″ class=”aligncenter size-full wp-image-5783″ />
AutomationDirect
www.automationdirect.com/proximity
Filed Under: Flanges • supports • mounts • brackets, Sensor Tips
