Rexroth IndraDrive ML: Now also for higher voltages and marine applications
By Lisa Eitel | May 20, 2016
With additional variants for the voltage range from 525 V to 690 V, Rexroth expands the range of uses of IndraDrive ML drives for outputs up to four megawatts. International and application-specific certifications reduce engineering effort for universal use in industrial machinery and equipment as well as in marine and offshore applications.
Wherever machinery and equipment requires drive power of several hundred kilowatt up to the megawatt range, the trend is toward higher supply voltages up to 690 V. The current is reduced due to the higher voltage and smaller wire sizes can be used. New facilities use almost exclusively devices with 690 V supply voltage, in particular in the paper industry, metallurgy, in marine and offshore applications as well as in energy generation. For these requirements Rexroth has developed additional variants of Large Electric Drives IndraDrive ML for the voltage range from 525 V to 690 V. They supplement the proven product line for supply voltages from 380 to 500 V. The space-saving, modular universal inverters generate drive power between 110 kW and 500 kW per device, and in parallel connection of up to eight devices up to four MW.
Bosch-Rexroth-IndraDriveMLRegardless of the supply voltage, IndraDrive ML is already certified for industrial application pursuant to CE, UL and CSA. This reduces the engineering and documentation effort for global use. All product lines are currently in the process of being approved by the ship classification authorities GL., DNV, ABS and LR. so that they can be used as “type approved” in typical marine and offshore applications, e.g. anchor and net winches or for hoist, slewing, and luffing drives for ship cranes.
IndraDrive ML can be operated as supply or frequency changer or as motor inverter. This minimizes variants, simplifies handling, and reduces storage costs for OEMs and end users. The universal inverters are particularly suitable for complex multi-axis applications. Drive-based Motion Logic solutions regulate synchronized movements via their own intelligence, even without higher-level control units. The certified safety technology “Safety on Board” also integrated in the drives reduces engineering effort for standard-compliant machine safety. With a multi-Ethernet interface for all common communication protocols and one multi-encoder interface, the drives seamlessly integrate even into heterogeneous automation environments.
Motion Control Tips
Tagged With: rexroth
Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
New gearboxes for electric motors in mobile machines
Leading motion-control and actuation options for robotics
Basics of wave and cycloidal gearing for robotics and servo designs
New micro servo-drive system for extra-low-voltage manufacturing applications
