Harmonic Drive LLC, a leader in high precision motion control adds Harmonic Planetary HPG gearheads with helical gearing and low reduction ratios to its current planetary gearhead lineup. Harmonic Gearhead products are available with quick lead times.
The new models, HPG-R, add low-speed ratios from 3:1 through 10:1 including all integer ratios in between. HPG-R employs helical gearing for improved noise reduction and higher torque capacity. Ideal for a variety of machinery and equipment designs, these new models enhance the already successful HPG series.
A special design of the HPG internal gear allows a preload of the gear and enables it to slightly deform elastically thus maintaining low backlash for the life of the gearhead, without any need for adjustment. This preload not only minimizes backlash but also compensates for interference between meshing parts. The result is low backlash for the life of the gear, without any “backlash creep”.
Like all Harmonic Planetary gearheads, the HPG-Helical gears feature quick connect coupling for easy mounting to any servo motor. They are also available with flange output, shaft output without key and shaft output with key and center tapped hole.
Harmonic Drive LLC has a dedicated website for its harmonic planetary and harmonic drive quick Connect gearheads.. The website offers users a quick and easy way to choose the best Harmonic Drive LLC product for their application. Developed with the design engineer in mind, the website features a robust product selector tool, PDF and DXF CAD drawings, as well as downloadable 3D solid models. The Product Selector Tool enables the design engineer to quickly filter through Harmonic Drive product specifications to find the right gearhead to connect to their servomotor.
About Harmonic Drive LLC
www.harmonicdrive.net
