Joyce Laird • Contributing Editor
All hydraulic hoses should be visually inspected on a regular basis, said Robert J. Koehler, Sr. Training Specialist at Eaton Corporation. Inspection intervals should be determined by the frequency of use and/or the application of the hose.
The more the equipment is used, the more frequently it should be inspected. For example, if a machine is used on a daily basis, then it is recommended that the unit be inspected prior to use each day and/or shift. It is important to do a visual check, as opposed to touching the hose, because running a hand over a hose can lead to serious injury.
You should complete the following steps for a visual inspection prior to operation, Koehler said. With power off, check the following:
- Check all hoses for leaks of any kind from the hose and/or fittings
- Check for damage to the cover, such as softening, abrasion, cracks, exposed reinforcement, blisters or bubbles
- Check for kinks, flat spots or a twist in the hose
“If any of these conditions are found, the hose should be removed from service. Also, a very important note: Never inspect hydraulic hoses with power on and always use proper PPE,” he added.
The post How often should you check your hose assembly for soundness and safety? appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
