These 100% polyalkylene glycol (PAG) lubrication fluids are designed for gearboxes, bearings and chains operating in the most demanding conditions. They provide thermal stability, extreme pressure and anti-wear performance and protection against micro pitting. They exceed 13 stages of the FZG test.
PGO Fluids are free of zinc and other additives that may be undesirable in environmentally sensitive areas. They offer long service life and work well over extended fluid change intervals which conserves resources and helps ease oil waste disposal problems.
Lubriplate
www.lubriplate.com
The post Eco-responsible, polyalkylene glycol lubricants for bearings appeared first on Bearing Tips.
Filed Under: Bearings, Bearing Tips
