    • On the Floor
A Better Way to Mount Flat Cables
By Design World Staff | August 9, 2010
Looking for a way to eliminate sometimes cumbersome cable carriers, inventors Howard Lind and John Palahnuk created the StripMount™ cable. The mounting design makes it quick and easy to mount cables to any surface without the need for cable carriers, conduit, or other cable management hardware.
cicoil-stripmount-aug
It is a fiberglass-reinforced ribbon that customers can add to any Cicoil flat cable. It is encapsulated in clear silicone jacketing, and it provides more than 250 lbs. holding force. These cables may be installed using screws, rivets, or with virtually any fastener available, making it quick and easy to securely attach your flat cable to any surface. In addition, multiple Cicoil flat cables can be stacked and attached to any surface.
Cicoil
www.cicoil.com
Filed Under: Cables + cable management, Machine tools + subtractive manufacturing, ELECTRONICS • ELECTRICAL
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
