A guide to spring-loaded pogo pin connectors
By Aimee Kalnoskas | March 26, 2025
Pogo pins are essential components in modern electronics, providing reliable spring-loaded connections for testing, charging, and data transfer applications. These small yet robust connectors ensure consistent electrical contact through a plunger mechanism, allowing for repeated use without significant wear. Their versatility makes them ideal for use in PCB testing, battery connections, and modular device interfaces, where durability and low resistance are critical.
The Same Sky blog post, Pogo Pins 101, breaks down the fundamentals of pogo pins, including their construction, working principles, and key design considerations. Learn about different pin configurations, plating materials, and how to select the right pogo pin for your specific application.
Read More
Filed Under: Connector Tips
