    • On the Floor
A2 Series Automotive Relay
By Design World Staff | March 4, 2009
Minneapolis, Minnesota ‚– The A2 Series is small in size and light weight. Offering both PCB pin and .250 Quick Connect terminals, the A2 is available with a weatherproof shroud along with mounting flange and metal bracket options. Coil voltage options are 6VDC, 12VDC and 24VDC with coil power choices of 1.6W and 1.9W. CIT Relay & Switch QS9000 and ISO9002 certified manufacturing insures quality and continuous reliability.
Typical applications for the A2 Series relay applications include automotive and lamp accessories: ABS control, cooling fan, blower fan, fuel pump, car alarm, trunk lock, window control and numerous others. Pricing ranges from $0.58 dependent upon options and volume. CIT Relay & Switch lead-time is 4 to 6 weeks.
www.citswitch.com
Filed Under: Automotive, Relays
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
