The new Model L18 absolute encoder provides system designers with high resolution in a small mounting footprint. This model features 13 bits (8192 counts) per turn resolution in only a 1.8-inch servo package.
Model L18 has the precision to be used in applications that demand high performance along with small size and weight. The L18 encoder contains field-proven ASIC electronics, sealed bearings and BEI‚’s accurate code disk in an all-metal housing to ensure its ruggedness and reliability. Ideal for space or weight limited applications requiring high accuracy, including semiconductor fabrication, industrial robotics, and mobile platforms. Now you can have a precision absolute encoder packaged to fit where others can‚’t.
Filed Under: Encoders • absolute, Motion control • motor controls
