Koyo Electronics manufactures and sells a wide range of electronic
control devices.
The size 15 series absolute multi-turn encoder is just one product available.
FEATURES
* 1.5” O.D. Hollow Shaft Design and Ultra Light Weight 1.0 oz
* Resolution: 17bit/turn (0 to 131,071 address), 16 bit turns
(65,536 turns)
* Response Turn Speed: 6000 RPM (Normal), 10,000 RPM
(Backup)
* Metal Disk: Strong in Vibration and Shock
* Flexible Backup Power Supply System-Priority whichever
higher voltage from main power
supply
(5v) or Ext. Battery
power or Internal backup power supply.
* EEPROM (memory chip) mounted as a Std. creates writing
& reading data.
* Application: Intelligent AC Servo Motors, Industrial Robotics
Injection Machines,
WaferTransfer Robots in
Semiconductor
www.koyoencoder.com
Filed Under: Encoders (rotary) + resolvers, Encoders • absolute, ELECTRONICS • ELECTRICAL
