AC-526N-CL, Very High Temperature Epoxy for Optics and Electronics
By EpoxySet | July 6, 2017
The AC-526N-CL from EpoxySet is a clear epoxy for applications requiring continuous operation at 300°C. This very unique, low viscosity adhesive yields very high electrical insulation properties with a low dielectric constant of 2.8. It is used in optical applications due to its high transmission rate and a refractive index of 1.56. High bond strength allows for use as an adhesive, sealant, impregnant and structural bonder. Once fully cured, AC-526N-CL exhibits a glass transition temperature of 190°C which will prevent movement in aligned parts even during temperature cycling.
The AC-526N-CL is easy to use with a 1:1 mix ratio and a 12 hour working time. It can be cured as fast as 1 hour at 150°C. Polymerization of this system creates a very tough plastic that offers excellent moisture, chemical and corrosion resistance as well as resistance to thermal and mechanical shock.
EpoxySet is an innovative custom formulator of Epoxies, Urethanes, Silicones and Greases for the electronic, medical, semi-conductor, optics, automotive and aerospace industries. Our extensive experience allows us to quickly modify our extensive product line for any requirement. Please contact our technical support staff at 401-726-4500
EpoxySet Inc. ● 1 Industrial Circle, Lincoln, Rhode Island, 02865, USA ● Ph: 401-726-4500, Fax: 401-726-4502
PCB mills
