The front panel mounting 3G3AX-MX2-EIP-A EtherNet/IP communication interface unit imparts network slave capabilities to the 3G3MX2 ac drives. The 3G3MX2 is a compact ac drive. It is equipped with Safe Torque Off (STO) function and External Device Monitoring output circuit (EDM), suitable for SIL2 as well as Cat3 installations defined by EN-954-1. Flow-chart “Drive Programming” with PLC-like function and simple positioning in open loop makes it suitable for simple single axis positioning applications. These reduce hardware and installation costs, and deliver faster performance when sequences are executed internally compared to handling these functions with separate devices. The drives are offered with all the globally accepted voltages (230 V, 460 V) and with the required power ratings (1/8 hp to 20 hp).
Omron Industrial Automation
www.omron247.com
Filed Under: Factory automation, Drives (ac) + VFDs + starters, Motion control • motor controls, Networks • connectivity • fieldbuses
