AC temperature controller features easy-to-use software and data retrieval capabilities
By atesmeh | June 7, 2013
Oven Industries announces the new 5R1-1400 AC Temperature Controller with the integrated potentiometers or via a PC through the TTL level UART Communication port. This compact design measuring two and one half inches square can deliver up to 15 AMPS of load current from a zero-voltage switched, low-noise, solid-state relay. Operator safety is achieved with 1KV of AC line power isolation for the communication port and sensor input. Specifications: Input Voltage 85 to 265VAC 50/60Hz, temperature resolution 0.1°C and Ambient Temperature Operation -20° to 70°C.
FEATURES
• Universal AC Input
• Integrated Potentiometers for Set Temp and PI Control
PC Programmable Set Temp and PID Control
• TTL Level UART Communication Port
• Set Temp Range Determined by Thermistor Type
• Open Sensor Protection
ACCESSORIES
• USB to TTL Interface Cable Model # OI-TTL-CABLE
• Flange Mount Model # 5R1-1400FL
• Temperature Sensor
Oven Industries supplies custom temperature controllers and sensors that serve an array of clients, from aerospace, automotive, biomedical, defense markets, medical and semiconductor.
From industrial temperature controllers to programmable sensors, Oven Industries creates many detailed and customized solutions for clients, designed by an expertly trained staff of engineers.
For more information about the 5R1-1400 controller, visit http://www.ovenind.com/bv/Products/5R1-1400-AC-Temperature-Controller__5R1-1400.aspx
