Accuride presents models 7950 and 7957, two new slides designed to expand the company’s heavyduty slide line-up and provide an intermediate load rating choice between the 3600 and 9300 products. The 7900 slides offer full extension, a load rating up to 350 pounds, and accommodate drawers up to 42″ wide. For added versatility, the slides may be flat mounted at a lower load capacity of up to 150 lbs. per pair.
Designed for applications such as mobile toolboxes and utility vehicle storage, the 7900 slides are a good drop-in alternative for .75″ side space projects, giving fabricators additional slide options for midrange loads, while increasing the aesthetics of the finished product.
Model 7950 does not offer a disconnect method, while Model 7957 has a handed lever disconnect. Both models have an enhanced ball retainer design, which mitigates retainer migration. Two special order models in a smaller cross section of .724″ are also available: models 7930 (non-disconnect) and 7937 (handed lever disconnect). All products are available in lengths of 12″ to 36″ in a clear zinc finish.
Accuride International
www.accuride.com
Filed Under: Factory automation, Linear motion • slides, Motion control • motor controls
