AccuStar® Electronic Clinometer from Sherborne Sensors
By John R. Gyorki | March 18, 2010
Sherborne Sensors has announced the AccuStar® electronic clinometer, designed to provide precision angular measurements within applications where a high degree of accuracy is required.
SherborneSensors_AccuStar
The unique design of the AccuStar® incorporates a capacitance-based sensor without moving parts. When rotated about its sensitive axis, this sensor provides a fundamentally linear variation in capacitance, which is electronically converted into high-precision angular data. Available in choice of analog, ratiometric, digital or serial models, the AccuStar® electric clinometer offers a ±60° measurement range, outputting a signal that corresponds to the direction and magnitude of angular displacement. The highly compact AccuStar® measures just two inches (50 mm) in diameter and weighs just two ounces (60 grams) for easy installation, with units designed to reliably operate in temperatures of -30 to +65°C. The sensor and its associated low-power CMOS electronics are encased in a rugged plastic housing.
With its durable, high-performance design, the AccuStar® is ideal for a multitude of applications, including off-highway vehicles, wheel alignment, construction equipment, antenna positioning and robotics applications, as well as other portable or mobile applications where space constraints or environmental concerns preclude the use of other types of precision angle measurement devices.
Sherborne Sensors
www.sherbornesensors.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
