AutomationDirect is pleased to announce the launch of several IEC and compact limit switches under the new house brand, AchieVe. These new AchieVe limit switches are available in a selection of sizes and styles, including:
- ADM/ADP series 50mm heavy-duty IEC limit switches
- AHP series 30mm plastic IEC limit switches with remote reset
- AEM/AEP series compact limit switches for confined spaces
These limit switches offer a variety of actuator styles, including plunger, lever, and a new pull-action style that is activated when a cable (sold separately) attached to the switch is pulled. This pull-action actuator, offered in the ADM series, is useful for simple start/stop control or signaling applications.
The AHP series 30mm IEC limit switches, with remote reset, feature a latching function that requires an external control signal to restore the switch contacts to their initial position and allow the switch to be triggered again.
The AEM/AEP series switches feature a super compact profile with a 25mm [0.98-in.] hole spacing, ideal for space-limited applications.
AchieVe limit switches are UL-listed, CE-marked, and RoHS-compliant.
AutomationDirect
www.automationdirect.com
You may also like:
Filed Under: Uncategorized
