    • Subscribe!
Acromag Ethernet Analog I/O Units
By Design World Staff | April 24, 2009
Acromag has expanded its BusWorks‚® Ethernet I/O series of modules for distributed I/O and SCADA with new 967EN and 968EN models providing an 8-channel interface for differential analog voltage or current input signals. Each model is available in industrial and commercial-grade versions starting at just $295 to greatly reduce costs for applications that do not need wide operating temperature ratings, advanced signal processing, or hazardous location safety approvals. The sub-$300 price is the industry’s lowest for an 8-channel module with 16-bit A/D conversion to Ethernet. Industrial-grade units add superior accuracy, a signal integrator/totalizer function, peer-to-peer messaging, -40 to 70‚°C capability, and are designed to meet UL/cUL Zone 2 Class 1 Division 2 ABCD requirements. All units provide 16-bit A/D conversion of sensor inputs for Modbus TCP/IP control network communication.
BusWorks Model 967EN and 968EN analog input modules for Ethernet control networks
Two models, each with 8 differential analog inputs, support a variety of I/O ranges. The 967EN accepts DC current with ‚±20mA, 0-20mA, or 4-20mA input ranges. 968EN models accept ‚±5V or ‚±10V ranges. Fast scanning updates all eight channels in less than 10mS. Dual-format data registers support both 16-bit integers and 32-bit floating point formats. IEEE-754 32-bit floating point scaling registers are configurable on a per-channel basis. A sample averaging function is also configurable. On industrial-grade units, an integration function can totalize inputs with non-volatile counter registers on all channels. Surge protection and 3-way 1500V isolation between I/O, power, and network circuits increase reliability.
These input modules are very easy to use. No software is required as the units are configured using any web browser to set operating parameters on embedded configuration menus. An auto-copy function lets users rapidly apply a saved configuration to multiple units. The automatic calibration function uses built-in precision sources and on-demand self-test capability verifies the calibration. Front-panel LEDs provide a visible confirmation of proper operation.
Acromag
www.acromag.com
Filed Under: Factory automation, I/O modules, Networks • connectivity • fieldbuses, Surge protection
Dual high-temperature Cabinet Cooler systems for large enclosures
    • Subscribe!
