    • Subscribe!
Acromag’s 16-channel BusWorks Module
By Patrick Curran | August 26, 2009
Acromag has released another BusWorks Ethernet I/O module to simplify the task of interfacing data from virtually any analog sensor to a Modbus TCP/IP control/monitoring system. The new 958EN model has 16 analog input channels and a quick-connect DB25 port to capture isolated and amplified sensor signals directly from a full panel of industry-standard 8B signal conditioners. This analog input module performs fast, 16 bit high-resolution A/D conversions to make the temperature, frequency, strain gage or other sensor data available to any control device via Ethernet communication. Typical applications involve processes requiring high voltage isolation or a mix of signal types such as with power generation, glass or metals processing, test/laboratory measurements and SCADA systems. Commercial-grade versions are affordably priced at $495. Industrial-grade models offer enhanced performance, -40 to 70C extreme temperature operation, integration/totalization capability, and are designed for UL/cUL Class 1 Division 2 ABCD (Zone 2) installations.
BusWorks Model 958EN analog input
Ethernet module with a panel of 8B signal
conditioners
The 958EN has 16 analog voltage inputs to accept ±5V and ±10V signals from 8B, or legacy 7B, signal conditioning modules through a standardized DB25 port connection interface. 8B modules support over 100 analog input types. Fast scanning updates all 16 channels in just 8mS. Dual-format data registers support 16-bit integer and 32-bit floating point formats. Users can read raw channel data based on 16-bit signed integer or 32-bit scaling registers, configurable on a per-channel basis, to minimize CPU or HMI software processing time. Surge protection and 3-way 1500V isolation between I/O, power, and network circuits increase reliability.
A sample averaging function is also included. Averaging is user configurable and improves performance in noisy or fluctuating environments. On industrial-grade units, an integration function can totalize inputs with non-volatile counter registers on all channels. Totalizing is ideal for flow applications, providing the ability to accurately measure actual volumetric usage on liquid, gas, electricity, and fuel flows. Users can read instantaneous flow signals and totalized volume data on each channel. Configuration and totalization information are stored in non-volatile memory which is safe in the event of a power loss.
These input modules are very easy to use. No software is required as the units are configured using any internet browser to set operating parameters on embedded web configuration pages. An auto-copy function lets users rapidly apply a saved configuration to multiple units. The automatic calibration function uses built-in precision sources and on-demand self-test capability to verify calibration and performance. Front-panel LEDs provide a visible confirmation of proper operation.
Acromag's makes available Modbus C Library software to greatly simplify the development of custom programs to interface with Acromag's BusWorks and EtherStax Ethernet I/O products. The library, Model ESW-MBLIB, also supports any standard Ethernet Modbus slave device that communicates via Modbus TCP/IP or UDP/IP protocol. This utility is ideal for developers that are unfamiliar with Modbus protocol or the framing of TCP/IP or UDP/IP messages. The C library makes programming easy and portable by simply linking user code with the provided function calls. Most function calls require passing only a few parameters such as the IP address, Modbus register address, and register count. The library can be used to develop programs in a Microsoft Visual C environment and with Linux™, VxWorks®, QNX®, or OS-9® operating systems. An example program and C source code are provided.
Acromag
www.acromag.com
Filed Under: Ethernet — cables • hubs • switches, I/O modules, Networks • connectivity • fieldbuses, Surge protection
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
    • Subscribe!
