Heavy duty priority flow control valves, also called ‚“hammer valves,‚†are a simple and efficient way to supply auxiliary hydraulic power to mobile work tools and attachments such as hydraulic impact hammers, compactors, saws, and cold planers.
The valves can be added to any existing hydraulic system without the need to modify its directional control valve. The valves feature zinc-plated steel bodies and IP69-rated coils that can perform in the most severe operating conditions of mining and heavy industry and are ideal for applications such as earthmovers, loaders, and excavators. These valves are now available for single pump, double pump or load sensing.
Bosch Rexroth
www.boschrexroth-us.com
Filed Under: Hydraulic equipment + components, Valves, FLUID POWER
