  • Articles
    • Electrical/Electronic
    • Factory Automation
  • Suppliers
  • 3D CAD Models
    • 2018 Winners
    • 2017 Winners
    • 2016 Winners
    • 2015 Winners
    • 2014 Winners
    • 2013 Winners
  • Engineering Resources
    • maxon motor driven
    • 3D Product Focus
      • Helical Machined Springs
    • Totally Integrated Automation
Additive manufacturing software eliminates the CAD-to-STL roadblock
By Leslie Langnau | February 11, 2019
Additive vendors are focused on streamlining the process of developing a design in CAD and then 3D printing it. Stratasys announced at the 2019 SOLIDWORKS World event additive manufacturing software that will eliminate the CAD to STL roadblock.
Stratasys is using its GrabCAD Print’s Advanced FDM feature to ensure design intent via intuitive model interaction will rapidly deliver strong, light, and purpose-built parts. Advanced FDM is designed to speed part production while maintaining creation of purpose-built parts that minimize weight without compromising strength.
GrabCAD Advanced FDM eliminates the CAD-to-STL conversion process – creating new possibilities for designers and engineers with 3D Printing.
“For design and manufacturing engineers, one of the most frustrating processes is ‘dumbing down’ a CAD file to STL format – only to require subsequent re-injection of design intent into the STL printing process,” said Mark Walker, Lead Software Product Manager at Stratasys. “This software is engineered to do away with this complexity, letting designers reduce iterations and design cycles – getting to a high-quality, realistic prototype and final part faster.”
Leaf spring U-bolt fixture, customized using GrabCAD Advanced FDM from Stratasys.
With rich CAD-native build controls, the solution doesn’t require manual generation of complex toolpaths – cutting overall programming times for 3D printing. Intuitive features achieve desired part characteristics through automatic control of FDM build attributes. Engineers easily select areas on native design geometry and specify design attributes – letting Advanced FDM automatically calculate 3D print toolpaths.
“GrabCAD Print Advanced FDM’s geometry-based workflows have allowed us to fine-tune part builds – meeting application requirements and process parts more quickly than we could before,” said Robert Heath, Additive Manufacturing Application Engineer at Eckhart. “The seamless transition of moving a build between applications is easy and intuitive.”
Assigning attributes directly to CAD models, users pinpoint areas of strength and rigidity, control infills, ensure sufficient material around holes with inserts, and avoid seams. Since toolpaths are automatically generated from model assignments, the user can expect to spend significantly less time on part setup, without losing strong, high-quality, purpose-built FDM parts.
“Advanced FDM has proved invaluable in improving our part processing time. When processing a large number of tools and fixtures in a time pressured environment, it was crucial to ensure stronger tool areas were correct first time, every time,” said Dave Hewitson, Rapid Prototyping Programmer at McLaren. “Advanced FDM negates the requirement for multiple programs – creating a more streamlined process. It’s also allowed us to more effectively control the structure of end-use car parts, something that was previously very difficult with the solutions we had in hand. This means we can get better parts to the track faster.”
GrabCAD’s Advanced FDM is available now via download with GrabCAD Print (from versions 1.24) and is supported on the following Stratasys 3D printing systems: F370, Fortus 380mc, Fortus 380mc Carbon Fiber Edition, Fortus 450mc, Fortus 400mc, Fortus 900mc, and F900.
Stratasys
www.stratasys.com
Tell Us What You Think! Cancel reply
DW EE Editions
Covering Microcontrollers, DSP, Networking, Analog and Digital Design, RF, Power Electronics, PCB Routing and much more
Tweets by @DesignWorld
  • Enews Signup
Copyright © 2019 WTWH Media, LLC. All Rights Reserved. The material on this site may not be reproduced, distributed, transmitted, cached or otherwise used, except with the prior written permission of WTWH Media. Site Map | Privacy Policy | RSS
  • Articles
  • Suppliers
  • 3D CAD Models
    • 2018 Winners
    • 2017 Winners
    • 2016 Winners
    • 2015 Winners
    • 2014 Winners
    • 2013 Winners
    • 3D Product Focus
We use cookies to personalize content and ads, to provide social media features and to analyze our traffic. We also share information about your use of our site with our social media, advertising and analytics partners who may combine it with other information that you’ve provided to them or that they’ve collected from your use of their services. You consent to our cookies if you continue to use this website.OkRead more
