  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
Additive manufacturing speeds the development and assembly of ball grid arrays and other SMT components
By Leslie Langnau | April 24, 2019
Nano Dimension Ltd., a leading additive electronics provider for electronics, announced that the company’s DragonFly Pro systems successfully shortened and simplified the assembly process for ball grid arrays (BGAs) and other surface mount technology (SMT) components used for integrated circuits. The 3D printers reduced the time from days to one hour. This could not be achieved otherwise, due to the extended timelines and typically complex BGA assembly processes associated with traditional production methods.
In a recent qualification study, Nano Dimension’s Application Engineering team demonstrated how the DragonFly Pro enabled a shorter and simplified end-to-end process for mounting BGAs and other surface mounted electrical components into printed circuit boards (PCBs). Typically, the process from initial design through printing, soldering, manufacturing, assembly and reflow takes weeks to complete. With a special layout structure that can only be achieved through additive manufacturing of PCBs, there is no need for special tooling for assembly. This enables in-house manual assembly of BGAs and SMT components during the design and application development phase.
Electronic devices with BGA and other SMT components are found in everything from small devices such as phones and watches, to large vehicles and airplanes. BGAs are a type of surface-mount packaging (a chip carrier) used for integrated circuits. A BGA provides more interconnection pins than can be put on a dual in-line or flat package, since the entire bottom surface of the device can be used rather than just the perimeter.
The in-house approach enabled by the DragonFly Pro eliminates all the stages of ordering and delivering assembled PCBs from external suppliers and enables companies to do more tests and feasibility studies that would not be possible without in-house additive manufacturing of electronics. Under existing practices, making needed design changes is tedious, as it involves back-and-forth communication between different suppliers, often leading to delays, creating difficulties in predicting development times, and putting the BGAs at a higher risk for errors. The DragonFly Pro 3D-printed socket structure improves mounting accuracy of the BGA component since there is less risk that the mounting position will shift.
“With the DragonFly Pro, companies can easily assemble BGA components within one hour,” said Amit Dror, CEO of Nano Dimension. “This means companies can do everything in-house, with no need for outside contractors, less risk of errors and they can complete complex PCB prototypes without high volume manufacturing processes. Greater flexibility enables teams to innovate more freely, resolve problems quickly, and makes it much easier to control product quality.”
Nano Dimension Ltd.
www.nano-di.com
Tell Us What You Think! Cancel reply
MOTION DESIGN GUIDES
  • With virtual commissioning, commissioning time and prototype waste is reduced
  • Master Bond Supreme 10HT High Strength, NASA Low Outgassing Approved Epoxy
  • Drilling Rig OEM Benefits from a PLC with Edge Computing Technology: IIoT Case Study
  • #1 Reason for Retaining Ring Failure & How to Overcome It
  • Motion controllers: design from scratch or buy ready-made?
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
