Adjustable Two-Way Connector Mini-Clamps
By Laura Carrabine | November 4, 2011
J.W. Winco, Inc. now offers series GN 475 Adjustable Two-Way Connector Mini-Clamps in metric sizes. Mini-clamps are typically used to build support structures for mounting sensors, Plexiglas guards, or other elements.
JW-Winco-Adjustable-Two-Way-Connector-Mini-Clamps
The clamping bores of these RoHS compliant mini-clamps are designed for GN 480.1 tubings. The two segments of the mounting can be twisted to accommodate the juncture of tubing at different angles. In the standard version, the clamping force of the clamp onto the tube is achieved via the socket cap screws. Clamp mounting is of aluminum and offered in either matte version (ground matte finish) or anodized version (black anodized finish). Cap screws are DIN 912, in stainless steel, while the grub screw is DIN 915, also stainless steel. Adjustable lever kits are available to replace the cap screws.
J.W. Winco
www.jwwinco.com
Filed Under: Clamps, Connectors (electrical) • crimp technologies, Fastening + joining • locks • latches • pins
molex-versablade-300x300
Heilind Electronics now offering Molex VersaBlade Wire-to-Wire Connector System
bel-stewart-m12xcode-connector
Stewart Connector M12 X-Code PCB mount connectors
Heilind-electronics-product-image
Heilind Electronics now offering Molex PowerPlane BusBar Power Connectors
Harting Technology Group heads for a climate-neutral future with record investment
