Adjustable Venturi Vacuum Pumps
By Patrick Curran | July 15, 2009
Hudson, MA – A new line of adjustable air-powered, venturi vacuum pumps that are designed for handling porous materials and operating in contaminated environments is being introduced by Anver Corporation.
Anver Q-VDF Series Adjustable Vacuum Pumps feature a diffuser section which can be rotated by the user to control the compressed air flow and provide vacuum flow rates to 120 SCFM and vacuum levels to 25”Hg. Ideally suited for handling porous materials and operating in dirty environments, these adjustable pumps allow debris to pass straight through their bodies.
Virtually maintenance-free, Anver Q-VDF Series Adjustable Vacuum Pumps have no moving parts and no gaskets or O-rings that can break down. Available with barrel sizes from 0.1” to 0.75” I.D., applications are as diverse as the pick-and-place handling of concrete block and packaging materials coated with fine powder, as well as air-driven industrial vacuum cleaners.
Anver Corporation
www.anver.com
Filed Under: Pneumatic equipment + components, Pumps
