    • Subscribe!
ADL Embedded Solutions
By Frank Tobe | February 11, 2014
ADL Embedded Solutions, a provider of customizable, high-performance embedded solutions for demanding thermal and rugged environments, announces its 150W ADLPS104ISO-150 power supply board. It’s designed to meet the needs of high-powered Intel® Core™ industrial and embedded motherboards by providing robust ATX voltages in a stackable PCI/104-Express form factor and is designed for -40C to +85C operation. The ADLPS104ISO-150 provides up to 500V of galvanic isolation from dirty power and unwanted transients. The power supply is tailored to work in conjunction with ADL Embedded Solutions’ advanced high performance SBC’s with more than enough headroom for inrush startup currents, and quiescent operation with multiple peripheral cards.
The ADLPS104ISO-150 boasts an MTBF > 600,000 hrs, is designed for extended temperature operation, and can be ruggedized for MIL-STD 810 and rugged industrial applications. It also features ATX compliant signaling to allow ACPI/APM power management from within compliant operating systems. The ADLPS104ISO-150 is available in two variants, one allowing an input voltage range of 7-36V but providing only the 5V, 5VS, and 3.3V outputs, the other with a narrower input voltage range of 15-36V but providing 5V, 5VS, 3.3V and 12V outputs. A MILCOTS filter option for MIL-STD 704/1275/461 applications is also available.
“The ADLPS104ISO-150 is tailored for long-life, rugged, embedded applications. It has been designed from the ground-up for rugged, long-life operation through a judicious choice of components and architecture that has resulted in an MTBF (>600,000 hrs) unequaled in the embedded industry,” according to JC Ramirez, ADL Embedded Solutions’ Product Manager.
www.adl-usa.com
Power Electronic Tips
Filed Under: Power Electronic Tips, Power supplies
Tagged With: adlembeddedsolutions
schurter
Compact power entry module has side flange mounting option
ABSOPULSE
Three-phase power supplies with active PFC handle 5-kW industrial applications
Sager Electronics to carry SL Power’s 300-W single-output power supplies
wuerth catalog
Catalog covers certified components for automotive electronics
    • Subscribe!
