ADL’s 150 W ATX Power Supply
By Natasha Townsend | June 28, 2012
ADL ‘s small form factor ADLPS35-150, 150W ATX Power Supply is designed to meet the needs of industrial and embedded motherboards by providing robust ATX voltages (5V, 5 VS, 3.3 V, 12 V) in a small form factor power supply designed for -40° C to +85° C operation.  Its small 2 in. x 4 in. size allows it to fit many space limited applications, is tailored to sit side-by-side with our 3.5 in. product line of motherboards and can also be adapted to a PC/104 stack via an optional mounting plate.
The power supply features ATX compliant signaling to allow ACPI/APM power management.  At 150 W total power, this small and rugged power supply will fit into most embedded applications. The unit is available in two variants. One unit allows an input voltage range of 7-30 V, but only provides the 5 V, 5 VS, and 3.3 V outputs. The second unit has a narrower input voltage range of 14-30 V, but provides 5 V, 5 VS, 3.3 V and 12 V outputs.  Both variants include over-current, over voltage, and short circuit protection.
 ADL Embedded Solutions Inc.
www.adl-usa.com
Power Supply Tips
Filed Under: Power Electronic Tips
