Advance Components now a master stocking distributor for Parker Fasteners
By Michelle Froese | May 20, 2020
Learn more about the Socket Head Cap Screws here.
Advance Components, an industrial fasteners master distributor, recently announced that it is now a proud stocking distributor for Parker Fasteners.
Parker Fasteners, a premier cold-heading manufacturer, is a top domestic manufacturer of Socket Head Cap Screws. Made of DFARS sourced materials, these Socket Head Cap Screws are available in both the 18-8 Stainless Steel and Super Alloy A286 styles.
Certified ISO 9001:2015/AS9100 Rev D., Parker products meet the highest standards in the industry.
Manufactured in the USA , these strong externally threaded screws offer the highest strength for commercial fasteners, and are the ideal fastener where there is not sufficient space for wrenches or sockets. They are often used in machine assembly and other industrial uses where panel installation requires a smooth appearance and elimination of bulky parts.
In many assemblies, using Socket Head Cap Screws require fewer screws as they are stronger than conventional screws. A hex key or Allen wrench is used on the internal hex socket drive to install the screws into applications that do not have enough space for traditional wrenches or sockets. Alloy steel provides a reliable response to heat treatment and it is both tough and strong at high strength.
Features:
  • Available in #0 to 5/8-inch diameters
  • Knurled heads are available
  • Variety of inches or metric sizes
  • Corrosion resistant
  • Heat resistant
  • Requires less space
  • Easy to install with Allen wrench or hex key
  • Strong holding power
  • Attractive finish
Tagged With: advancecomponents
