The Goldeye G-008 SWIR is packed with all the features and benefits of the current Goldeye camera family, combined with a smaller resolution sensor. As a result, its attractive price lowers the entry barrier into short wave infrared image processing.
The Goldeye G-008 SWIR is fitted with a QVGA InGaAs sensor (320 x 256 pixels, 30 µm pixel size) making it sensitive in the short wave infrared spectrum ranging from 900 to 1,700 nm. With this smaller imager, the cost for this new Goldeye could be significantly reduced compared to the existing VGA resolution models. Thanks to this lower price, infrared imaging becomes affordable for many cost-sensitive applications in which the lower resolution is enough to do the job–for example hyperspectral imaging applications such as plastics sorting for recycling purpose or environmental analysis, high-temperature thermography in the steel and glass industries or laser beam profiling.
Users of a Goldeye G-008 SWIR won’t have to trade off quality or speed for the low price. The new model has all the qualities of the popular Goldeye family and delivers 346 fps (frames per second) at full resolution. For example, the camera’s industrial-grade housing is extremely robust and compact (55mm x 55 mm x 78 mm) to fit into the smallest machines. Various mounting possibilities, extensive I/O functionalities and a large choice of lens mount options ensure an even easier integration.
The Goldeye G-008 SWIR relies on the GigE Vision industrial standard as an interface. Thanks to its GenICam compatibility, the camera can easily be used with the most popular image processing libraries. With Allied Vision’s powerful software development kit Vimba, which is available free of charge to Allied Vision customers, users can program their application across platforms (Windows, Linux, etc.).
The Goldeye G-008 SWIR also features all image correction and optimization functionalities of the Goldeye family such as advanced image correction algorithms and fan-less sensor cooling using a thermoelectric module (TEC 1) for low-noise images.
The Goldeye G-032 SWIR with VGA resolution (0.3 Megapixel) and 25 µm pixel pitch stands out of the crowd with its high dynamic range (74 dB). It is available as a COOL version with enhanced sensor cooling (TEC 2), allowing for low-noise images even at long exposure times, for example in demanding low-light applications.
The Goldeye G-033 SWIR is also fitted with a VGA sensor. While its pixel size is smaller (15 µm), it delivers a very high frame rate of 301 fps at full resolution (640 x 512). It earned an Innovators Award 2015 from Vision Systems Design magazine as the fastest SWIR camera with GigE interface in the market. Thanks to this high frame rate, many machine vision applications can be sped up to increase productivity, some of which also benefit from the smaller pixel size of the sensor – for example wafer inspection or hyperspectral imaging.
The Goldeye G-008 will be available starting August 2015.
Allied Vision
www.alliedvision.com
Filed Under: Sensor Tips
