Advanced Motion Controls releases EtherCAT® Servo Drives and ‘DxM’ Technology
By Stacy Combest | August 28, 2012
Precision has been given a boost with the advent of EtherCAT®, an open Ethernet-based network standard setting new heights for real-time performance and topology flexibility, and has been the fastest growing area in motion control technology.
ADVANCED Motion Controls’ powerful DZE & DZS series of servo drives for EtherCAT enabled control networks with package size that can easily fit in the palm of your hand. These products not only provide precise motion but also at reduced cost when applied in a multiple networked axes system.
ADVANCED Motion Controls also created ‘DxM’ – Demultiplexed Motion technology allowing connectivity of up to 3 DZS drives (sub-nodes) to a single DZE (node) on an EtherCAT® network for up to 4 axes of servo motion. Removing the cost of additional EtherCAT® nodes greatly reduces overall system cost. ‘DxM’ technology handles all sub-node activity easily through one node, making master tasks much simpler in multi-axis systems.
The DPE series of EtherCAT enabled servo drives as part of the panel mount DigiFlex® Performance™ platform. Both DPE’s and DZE’s can be used as stand-alone EtherCAT® slave nodes in single-axis setups or as part of a larger, multiple axes EtherCAT network. The DZS’s must be used as sub-nodes in a ‘DxM’ configuration with a DZE node.
More information
www.a-m-c.com
Motion Control Tips
Filed Under: Motion control • motor controls, Motion Control Tips
Tagged With: advancedmotioncontrols
