Cincinnati, Ohio — The Industrial Automation Group of Advantech introduces two new signal conditioning modules, the ADAM-3112 and ADAM-3114. The ADAM-3112 is an isolated AC voltage to DC voltage module while the ADAM-3114 is an isolated AC current to DC voltage module. These two signal conditioning modules can convert up to 400 VAC or 5 AAC signals to 0~5 VDC signals for data acquisition cards to measure while reducing the harmful effects of ground loops, field noise, and electrical interference.
Compared to other signal conditioning products, the ADAM-3112 and ADAM-3114 possess robust high voltage isolation so that they can be exposed to severe environments and still protect the system from high voltage input or power. Both modules provide 1,000 VDC between output and power; 2,500 VRMS between input and output and between input and power. More importantly, the ADAM-3112 provides three input modes, 0~120 VRMS, 0~250 VRMS, and 0~400 VRMS in one single signal conditioning module, which makes it versatile, compact, and cost effective by eliminating the use for three individual modules for three different voltage-level applications.
These modules are suitable for DIN-rail mounting, designed for easy wiring, and can be connected through screw terminals which simplifies wiring and maintenance. For more information, or to purchase, please contact Advantech at 1-800-205-7940 or your regional Advantech authorized distributor.
Advantech
www.advantech.com/ea
Filed Under: Data acquisition + DAQ modules, Signal analyzers, ELECTRONICS • ELECTRICAL
