    • Subscribe!
Advantech Launches High-Performance 4U Industrial Panel PC
By Patrick Curran | April 30, 2009
The Industrial Automation Group of Advantech introduces the IPPC-4000D, a 4U 19” rack mount Industrial Panel PC with a 5.7” VGA TFT LCD. With a built-in ATX industrial motherboard, Intel® Core™ 2 Duo or Pentium® 4 processor and up to four or eight GB DDR2 SDRAM respectively, the IPPC-4000D is one of the most rugged, feature-rich, and powerful industrial panel PC’s on the market. The industrial ATX motherboard reduces interconnections between the backplane and CPU card, enhancing the platforms reliability. Also, dual front-accessible filtered cooling fans provide optimal streamlined airflow.
The IPPC-4000D comes with seven extension slots (5 x PCI, 1 x PCIe x 16, 1 x PCI e x 4) or (5 x PCI, 1 x ADD2, 1 x ISA), three front-accessible 5.25” HDD, one 3.5” HDD, and an option for four hot swappable 2.5” SATA HDD’s. There are multiple standard communication ports (4 x RS-232 with cable and bracket, 1 x Gigabit Ethernet port, 6 x USB 2.0 ports {two in front}, 2 x PS2 ports, VGA, Parallel and IEEE allowing connectivity with a variety of peripherals. The IPPC-4000D supports Microsoft Windows® XP/Vista™.
The IPPC-4000D is designed for use in video surveillance and monitoring applications which require massive amounts of easily replaceable storage.
Advantech
www.advantech.com/ea
Filed Under: Electronics • electrical, Industrial computers
Tagged With: advantech
molex-premo-flex
    • Subscribe!
