Advantech’’s Elegant Entry Level Industrial Panel Monitors
By Editor | December 19, 2013
Designed especially for machine and factory automation, Advantech’s ITM-51xx series of 12”, 15” and 17” completely flat touch panel monitors are not only great looking but, with a wide operating temperature range and rugged casing, make them perfect for harsh environments.
Advantech
The LED backlight display provides a power saving of 20-30% and since it comes with a 5-wire resistive touch screen, it is even more accurate to the touch. The use of the LED backlight also enhances readability and increases the life of the panel.
For the purposes of easy cleaning, the ITM series have an entirely smooth flat panel that is IP54 protected and has absolutely no ridges. To further aid the ITM models being used in harsh environments, they have an operating temperature as low as -20°C and as high as 60°C.
For versatility, they have VGA and DVI input interfaces and a combo RS-232 and USB interface for touch usage.
Advantech
www.advantech.com/ea
Filed Under: Factory automation, Displays • HMIs • operator interfaces • monitors, MORE INDUSTRIES, MOTION CONTROL
Tagged With: advantech
