    • Subscribe!
Advantech’s Latest Embedded Automation Computers
By Design World Staff | April 20, 2011
The Industrial Automation Group of Advantech has upgraded three of their highly successful fanless Embedded Automation Computers, the UNO-2050G, UNO-2053GL, and the UNO-2059GL.
The UNO-2050G has an onboard AMD Geode LX800 500MHz CPU with dual LAN and 8-channel isolated digital input and 8-channel isolated digital output with timer and counter. It supports two RS-232 and two isolated RS-232/422/485 communication ports with RS-485 automatic flow control. There are two 10/100Base-T RJ-45 ports and supports Windows® CE 5.0 & 6.0, XP Embedded SP2, and Linux.
The UNO-2050G
The UNO-2053GL has an onboard AMD Geode LX800 500MHz CPU with dual LAN and two 10/100Base-T RJ-45 ports and two USB 2.0 ports. There is audio with mic in, line in, and line out and one DB-15 VGA connector. It supports Windows CE 5.0 & 6.0, XP Embedded SP2, and Linux. The UNO-2053GL is ideal for ThinClient operations.
The UNO-2059GL has an onboard AMD Geode GX533 LX800 500MHz CPU with one 10/100Base-T RJ-45 port and two USB 2.0 ports. There are two RS-232/485 and two RS-232/422/485 communication ports with automatic flow control. One programmable diagnostic LED and buzzer and supports Windows CE 5.0 & 6.0, XP Embedded SP2, and Linux.
Advantech
www.advantech.com/ea
Filed Under: Factory automation, Automation components, Industrial computers
Tagged With: advantech
Dual high-temperature Cabinet Cooler systems for large enclosures
    • Subscribe!
