Advantech Industrial Automation Group is pleased to announce that the multifunctional PPC-6120 has had an upgrade and now comes with the ability to allow users to install the processor of their choice.
Flexibility is the key to this upgrade. Choose any 4th generation processor, from low-end Celeron to the powerful Intel® i7, to meet your needs.
The PPC-6120 is a 12.1” five-wire resistive touch screen and is idea for connecting directly to devices through an integrated isolated RS-422/485 port which protects the port in the event of power spikes. If however, a larger screen is required, users can simply attach two extra displays using the VGA and Display Port which can be used simultaneously with the PPC-6120.
For added reliability, as well as the isolated RS-422/485 port, the PPC-6120 comes with a wide voltage input range of 12 to 30 volts so in unstable power conditions, the PPC-6120 will continue to work.
The PPC-6120 also comes with the following features: IP65 front bezel, four RS-232 and four USB 3.0 ports, dual Gigabit ports and, a PCIex4 or PCI card can be added.
Advantech
www.advantech.com/ea
Filed Under: Industrial computers, MOTION CONTROL
