Webinar: After the Press: Utilizing Downstream Fabrication to Create the Aluminum Extrusion-Based Solutions You Need
By Kim Dorsey | September 10, 2020
This webinar was presented on Wednesday, October 14, 2020
Please click below to watch on demand
With most aluminum extrusions, the long length of a desired shape that comes off the press is just a starting point. Rarely are these profiles used as they were extruded. In almost every case, there is subsequent cutting, drilling, milling, machining, bending, joining and/or finishing required to transform the extrusion into a component or sub-assembly for inclusion in a final product.
This webinar will recap the fabrication processes typically employed, with an emphasis on extrusion design considerations that can reduce fabrication costs.
Attendees of this webinar will learn to:
  • Identify the process factors that affect the cost for aluminum extrusions
  • Outline the different types of fabrication operations that are typically employed with extruded profiles
  • Explain the different functionalities that can be incorporated into extruded profiles to optimize fabrication
Featured Speakers:
Jeff Bladow
Director of Business Development
Taber Extrusions
Jason Weber
V.P. of Sales & Marketing
Taber Extrusions
Leslie Langnau
Managing Editor, Moderator
Sponsored by:
Filed Under: WEBINARS
Tagged With: Aluminum Extruders Council
